Im workin on replacing the head gasket on my 93 Festy L. I have a Haynes manual for the 88-97 festiva/aspire. In the diagram for the removal of the crankshaft pulley, it says I need to first, remove 4 bolts. I did that. Next it says, remove the crankshaft outer pulley retaining washer. I did that..but the washer that came off only had 4 bolt holes, 1 hole for a notch on the other pulley (most likely to align it) and then the bigger hole in the middle. The washer in the book has 6 smaller holes on the outside, not 5, also in the wrong pattern. Well next it says to remove 2 small screws to remove the inner pulley and its inner spacer. But, there is no screws. None. Ive looked for like 30 minutes, with flashlights and even had my girlfriend look. Nothin. But yet the only bolt or anything I can see is the crankshaft bolt (I think) which is in the middle and doesnt llok like its holding the pulley on. But believe me that sucker is not comin off....So anyone know whats goin on or does anybody have the same problem?
