Reinstalling oil pan with new gasket. Does anyone know the torque specs for the pan? Also is there a pattern to do em as well? Thanks in advance!
Oil Pan
best just to buy a new Festy without an oil pan leak.....I will relieve you of the stinking leaking mess of a car if you need it gone."FLTG4LIFE" @FINALLEVEL , "PBH"
bah you no help! Got festy almost tip top shape.... i might consider giving it to you once festy is all rusted out and gutted out just an empty shell for you....of course no wheels on it either so you will have to slide it home!Originally posted by GenevaDirt View Postbest just to buy a new Festy without an oil pan leak.....I will relieve you of the stinking leaking mess of a car if you need it gone.
lol....well....I do not think I will be wanting it then. Sheeeeesh.....try to help a guy out..."FLTG4LIFE" @FINALLEVEL , "PBH"
70!?!?! i hope you're measuring in in-lb. but that's not all that high, shouldn't have snapped a bolt at 6 ft-lb.Trees aren't kind to me...
