I'm sick and tired of fighting the lever to get my car started. How can I bypass the neutral safety switch in my automatic?
Auto Neutral Safety Switch
you can't.... j/k have to hardwire the switched closed, but i don't recomend this. i would first try to replace the switch.Trees aren't kind to me...
There is a good chance that it is the contacts inside the switch that aren't working properly, in which case no amount of adjustment is going to help. I don't know if the switch is on the trans or the shifter, but if its on the shifter you can probably open it up and try to clean the contacts. If its on the trans its probably encased in metal and not about to open though. I had to take apart and clean the one on my wife's volvo, same type of problem you're having. Its working fine now
Edit: just looked it up and its on the trans. Have you tried testing the switch for proper operation while its out of the trans?Last edited by htchbck; 03-08-2011, 06:58 AM.No festiva for me ATM...
