won't pass emissions.
  • won't pass emissions.
    My festiva won't pass smog test. I retarded the timing to spec white mark on crank. New plugs, wires,cap and rotor. New cat converter, midpipe and muffler. I ran seafoam thru it. And water misted the intake. And cleaned the throttle body.
    The HC and co2 values are where they should be, but the nox are thru the roof high.
    Is there something I'm missing.... its a 92 efi automatic. Any suggestiond would be awesome.
    Thanks..... colby
    run some high test in it next time. that NOx should be taken care of by the cat but if they're STILL high, then you're pinging, even if you can't hear it.
      Its full of high test. And the timing is so retarded it is ridiculous.
        Oxygen sensors,, and CRC guaranteed to pass
        Hello, I got the same problem last year,,
        When I got the cat installed , I also replaced the Oxygen sensor,, and run a tank of gas with a bottle of CRC guaranteed to pass,,
        then I passed smog and my NO levels are zero.
          GOT IT TO PASS!!
          i ended up changing the o2 sensor, after a check engine light came on, and i read the code. i can now go register it, and advance the timing to where it will actually run well
            Congrats! Had mine failed the test because horn didn't work! After a minute or two cleaning the connectors it passed Hah!
              Congratulations!
