is there a difference in efi and carbed Cam Shaft on a b6
  • is there a difference in efi and carbed Cam Shaft on a b6
    I have pieces of my engine floating all over town now. so I can not check to see if this will drive the mechanical fuel pump or not. can someone verify that this cam will drive a fuel pump?
    if not i would like to have time to find a new one.
    thank you
    Sam
    Slacker Sam
    looks like you have a pump lobe there right behind the dizzy slots, though it looks like it's not been ground to run a pump (hard to tell from picture).
      it looks about right you can see it comes closer to the cam on the top left and juts out top right and right. ok ill shut up now
      It's Not Much To Look At, But It's Still Funny To See The Look On Their Faces When They Catch Back Up To You At The Next Light!
        new pic
        does this help?
        Slacker Sam
          pump lobe is there just never used
            I'm with FestyBoy, If it isn't out of an Aspire b3 it will work. The EFI festy's had the lobe and a cover on the head that could be removed with two bolts and used on a carby engine with ease.
            91 Festiva GL "Scrat"
            82 Honda Goldwing GL1100i
            85 BMW 535is "Brunhild"
              May want to polish the pump lobe some. It would be easier on the pump arm.
              It looks a little rough in the pic.
              I would think that all the camshafts would have the lobe for the mech fuel pump, unless of course, they did away with it in the later efi model years to save on material costs. Correct me if i'm wrong.
              Dan
                wow looks just like my fms performance cams =0 but mines look like it has better material =)
                  is it already sandal weather up in ND??
                  -Aspire brake swap COMPLETE!
                    im in LA
                    Sitting shorts an t-shirt in LA.
                    Got the lobe surfaced today. Cam guy said " I don't work on Mazda's but give me $20 and I will make it shinny" I got the head back from the shop it looks great. tossed the pump on and put the cam in. I could turn it by hand all the way around with a lot of effort. it appeared to activate the pump and did not seem to bottom it out either hope it works
                    picture coming soon.
                    Sam
                    Slacker Sam
