Hi Guys,, I tried installing a new Brake Pad, followed all the steps on the Haynes Manual,, Deppressed the Caliper Piston, was able to slide a new brake pad on the inner side (caliper Piston side),, but on the outer side,, there was hardly any space, I was able to pull the old outer Brake pad but there was just no space for a new thicker Pad,, I did not expect it to bump into this issue, I was in the impression that when you deppress the caliper piston there will be space on both sides for a new Brake pad,,
should I be replacing my rotor? or calipers? Please help me on this issue,,
92 L ,,stock Brakes
I would really appreciate all comments or suggestions..
92 L ,,stock Brakes
