I have a '93 GL. Does anyone know if its going to be 134 or R12 and how can I find out if it could be either way. According to my book it should be R12 which sucks but this car seems like it was maybe a real late 1994 because some of the engine compartment stuff is located a little different.
A/C 134 or R12
Most air conditioned cars have a label either on the very front of the engine compartment or on a shock tower specifying oil, refrigerant, and charge amount, but I'll assume that it has disappeared.
The big give-away is the service ports. Remove the caps from the ports and take a look. One port should be on or near the accumulator can, the other on one of the lines coming from the compressor. R-12 used a schrader valve (like a tire valve stem), R-134a uses a quick attach coupler (like air tools). If it has couplers screwed onto schrader valves then it has been retrofitted to R-134a. If a shop did the retrofit, they're supposed to put a label over top of the old one.91 L 5sp "The Silver Bullet" B6, Brake/Susp Swapped Build Thread
92 L 5sp "Red" RIP
95 Grand Prix SE DD
Wife's Stuff:
89 L 5sp "Carby Car"
97 Aspire auto "Pink Panther" Build Thread
Spring 2013 IndyStiva:
http://www.fordfestiva.com/forums/sh...eet-April-20th
R134 started in 1994 or 1995, depending on the car model I think. Definitely not 1993.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
If you do retrofit to 134A remember it only takes 20 to 21.5 oz of freon not 24oz. the reason is, the molecules in 134 are larger than the R12 and takes less to fill the system. Good luckAn idea can turn to dust or magic, depending on the talent that rubs against it.
Check the fire wall and see if a tech put up a tag saying it was converted, i'll try and get a pic of mine for you, any way if it has a tag it will be on the left side of the fire wall.An idea can turn to dust or magic, depending on the talent that rubs against it.
R12/r143a
I have a '93L, & its 134. Not converted, no adapters. I called an A/C shop & ask. The Mang. said bring it in, He looked at it & confermed 134. Told me to go to a parts store & buy a kit, that it would be cheaper than the shops prices. $27.+ change at McPepboys. The chart says '93L's do not have A/C. It looks factory.;-)
Mine is a '93 GL it has a R12 decals and the screw on adaptor but no other decals on it. I might just have the guys in town take a look and see what they think. I've got a gauge that I use on the others to fill them and some 134 its not hot enough yet I just want to get it figured out before it does.
