Originally posted by nitrofarm
Weber conversion Q's (Many Pictures)
.... How about some pics after you make all the modifications so we can see how it worked out and generally looks. Your BEFORE and AFTER pics would be good for those making the changes in the future.
Thanks
He stated that he has no pcv on the carb? What is that Large black vaccum plug on the carb? Aint that where the pcv would go? I'm used to holleys and havent got my Weber yet? But there has to be some provision on a Weber right?
Originally posted by TominMO View PostAnother thought....for E, you have an alternative to the breather filter setup. If you have the Weber air filter housing, you should have a small hole in the bottom housing, and a plastic L-shaped hose fitting to go in it. It is there so that you can connect the breather fitting (E) on the valve cover to it with a hose, to recirculate the gases coming out of the breather.
Another thought....for E, you have an alternative to the breather filter setup. If you have the Weber air filter housing, you should have a small hole in the bottom housing, and a plastic L-shaped hose fitting to go in it. It is there so that you can connect the breather fitting (E) on the valve cover to it with a hose, to recirculate the gases coming out of the breather.Last edited by TominMO; 03-21-2011, 06:05 AM.
Doy, Tom got most of your Q's, but the throttle cable adjusts with the nut and washer right at the bracket that it mounts to on the valve cover. You may have to do some modification to the bracket, or move it, depending on the carb set up you have. The cable should have the play adjusted almost completely out of it. A little slack is all you need. Just enough so the throttle closes on the carb.
Really all the vacuum lines work just the emission feedback carb you no longer have. So none of the lines are needed, except for the PCV valve and Distributor. Basically, with the Weber it is OLD SCHOOL...engine and carb feeding gas to the cylinders, no emission stuff.
If you have more Q's, PM me and I will try to answer them. I also have a bunch of pics of my existing lines to the disty and pcv and throttle hookup.
BTW, that is one sweet setup! Nice intake and carb.
I think bravekosak has a way to hook the PCV into the EGR port since you dont have a place on your intake for the PCV.Last edited by drddan; 03-20-2011, 07:43 PM.
Originally posted by zoe60 View PostIf you keep the MAP sensor (left side of G) hooked to vacuum it will help keep your check engine light from coming on. Just use a tee. I think that's hooked to the same place as the distributor vacuum advance. It's not hurting anything being there but a check engine light that won't go off will drive you nuts.
As for H, those tubes do actually connect to the air in the cat and the exhaust manifold. I looked this up in my Haynes manual (page 6-2, Pulse Air System). What you could do is connect them to each other with a hose, like Dan did. Then for sure they wouldn't be spewing exhaust gases into the engine bay. Or you could cut them shorter and plug them, too.Last edited by TominMO; 03-20-2011, 10:25 AM.
Edit to my post above....Dan had not yet removed all of the H stuff, so don't worry if you see it in his pics. You'll notice a hose connected to the tube that comes up from the cat. Just remove all you can, right down to the cat. Same for the tube coming from the exhaust manifold.
Further edit....Oh right, you're using the new manifold. Just make sure you have locations available on the intake manifold for the vacuum lines to the disty, and the PCV connection too. Good point Kozak made.Last edited by TominMO; 03-20-2011, 10:02 AM.
Once upon a time, cars used to have a tube dangling off the back of the engine and used moving air to draw out the crankcase vapors so that there wouldn't be varnishing of the valvetrain. It later became hooked to a manifold vacuum source so that the fumes could be drawn back into the combustion chambers. It is unwise to not have positive crankcase ventilation.
I would refer you to drddan's thread for pics and commentary:
Yes, we removed a whole bunch of stuff! A - H can all go. Just keep the PCV valve (D) and the vacuum lines to the disty, and put a small breather filter (under $10 at McParts store) on the valve cover where that hose is (E). I can't identify all those pieces and don't care anyway. It was all emissions-related crapola. We took 'em off Dan's car and it runs great. You'll have to plug a few holes on the intake manifold, but that's easy. For H, one goes to the cat and one goes to the exhaust manifold. They are just heat risers, and don't actually connect to the air in the cat or in the exhaust manifold, so just get rid of as much of it as you can, and don't worry about the rest.
See post #26 in Dan's Weber thread for pics of the completed setup. See post #11 for all the stuff we took off. In the first pic in post 26 you can see the two vacuum lines going to the vacuum advance attached to the disty.
For the throttle cable, I like to have just enough play that you can tell it is barely loose at idle, but no more.Last edited by TominMO; 03-20-2011, 09:49 AM.
Installing a Weber style carb. with a modded intake with no pcv connection...
I know, there is already a thread or two, or 12... Probably already answered, but I am really baffled on this!
I am stupid / a newbie when it comes to carbs / vacuum lines. I know, and I'm sorry to put you through all this. In the posts I read, it says to just remove all the hoses except the disty vac lines and obviously the fuel line. Well, I can't imagine removing THIS many! I mean I don't know where they go, or what they do, or how to remove them or anything. I am sure someone else out there will need / appreciate all the information you guys / gals can give me as well. I have included some pictures pointing out what is in question. Pretty much everything vacuum or fuel related looking... Please be as detailed as possible. Please don't just say, "Yes, you can cut that off." Please tell me what it goes to, and the method of removing it as to not cause any issues. This thing has been broken down for too long, and I am finally able to tinker with it a little.
A= vacuum line going to air cleaner / breather... Not using the same breather, so I don't figure I will even need to worry about transferring this to the new carb.
B=What in the heck is this, and do I need to keep it? If I can get rid of it, where do the lines go, and what do I do with them or what they connect to?
Just under the letter B, same questions.
C=Same as B.
D=PCV valve, I know that, but I am going to run without it. What did everyone else do to this step?
E=Tube that went to breather I'm not using. I have seen some pics on here that a few of you guys have put on with some kind of filter looking thing in that hole. What is it, where do I get one, how expensive... etc... With that, would I still need something for the PCV, or would I just plug the hole?
F=The whole picture is F. What is all this, and can I remove it?
G=Same as F.
H=These went into the thing(?) on the side of the old breather. Do I need these? Can I remove them, where do they go, do I plug them off, etc...?
Also, how much play should be in the throttle cable? I can remove it from the arm quite easily without moving the arm or applying much pressure to the cable. Should it be adjusted? If so, how should I do this, and how tight should it be?
Edit: Sorry about the size of the pictures, on photobucket it said resized, but some are still larger than others.Last edited by doylerl; 03-19-2011, 05:48 PM.Tags: None
