HLA questions
  • HLA questions
    Hello all,
    I think I have a HLA (hydraulic lash adjuster) that's gone south on me. I had one occasionally making a little noise on startup then quiet done fairly quickly. The other day it started out noisy, quieted down then started up again. The noise hasn't stopped since. I have a couple of questions....
    If the noise is coming from the HLA would it get louder if you took of the oil filler cap?
    I have a B6 with manual adjusters sitting in the back yard. Could I just switch the rocker arm assmeblies into the B3?
    The best price I could get for new HLAs was about $37.00. I'm thinking a trip to Pick 'N' Pull may be in order. I know there are no FI Festivas there right now which brings me to my next question. Are the B6 &B3 HLAs interchangable?
    I hope the HLA is the problem. Even though I have the B6 waiting to go in I don't have the time or the finances right now to do the swap.
    I'm confident that the right answers will be forthcoming
    Thanks
    Ian
    Hello again,
    One thing I forgot to mention is that I did a Seafoam treatment no too
    long ago and have since changed the oil.
    Oil has been changed every 5000km.
    Ian
      I got mine for $11 from www.rockauto.com
      www.auto-rx.com had cleaned my HLA enough to for them to not make noise....until winter hit. So if yours aren't too bad auto-rx may be able to help them.
      www.dantheoilman.com
      Go ahead and ask me why
        Problem solved.... went to pick n pull and pulled the HLA's from an early B6. It turned out that the HLA for the #2 intake valve had collapsed so I replaced it.
        Thanks for the comments.
        Ian
