I forgot you have a Weber not a Holley. Weber float level is bench set upside with a measuremant. But here is a way you can cheat if your handy and have a metric bleeder. I stole the following from another site:
you can hook a tube into your Weber's float bowl drain plug and then run the engine and not only can you set the float level, but you can see if the pumps can keep up.
construction of this devices seems complicated, but it is in fact amazingly easy. the weber float bowl drain is an 8x1.00 thread, which just so happens to be the same as the brake or clutch bleeder screw on every stock mazda rotary.
you then use the same clear tubing you'd use to bleed the brakes. the weber drain plug comes out, the bleeder screw goes in like its made for the job, and it will seal on the weber crush ring.
turn on the fuel pump(s) and look for leaks.
Mazda's spec for float level is 21-23mm down from the top of the throttle body/float chamber.
