A tip with any T-type oil seals, cam, crank, rear main, axle, is to never have them ride in the exact same place as the old seal did. Anyone that's changed a rear main probably notice a tiny groove in the crank, that from the seal. If you don't install the new seal quite as far as the old one you can usually get it to ride on a fresh surface.
axle seal leaking. any ideas??
Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
That's the brand I haves used for the past 20 festys and I've never had any leak issues.Originally posted by Pgh5spd View PostI've used National / Federal Mogul 2007N's for the last many years because since they had to order them and they were only $5 then, I got a six-pack. Except for once not seating one properly, they've never leaked on me.
Maybe it's a parts brand quality thing.
Thats good advice DennisOriginally posted by gauge_half_inch View PostA tip with any T-type oil seals, cam, crank, rear main, axle, is to never have them ride in the exact same place as the old seal did. Anyone that's changed a rear main probably notice a tiny groove in the crank, that from the seal. If you don't install the new seal quite as far as the old one you can usually get it to ride on a fresh surface.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
