Lost my ignition key to my 88 and 89 festiva
  • Lost my ignition key to my 88 and 89 festiva
    What can I do please.
    Remove your passenger side door lock cylinder. It has a key code on it that any reputable locksmith can use to make a key.
    My Fleet:
      grab another one from the JY , ive got 4 from random festiva keys that will unlock and start my car.
        That is really good news, thank you. I don't know how I'm going to get those locks out but I will get it done. Thanks again.
          I'm in a rural area and the junk yards have none.
            Haha skims keys unlock n start my 88
            -M3NTAL MARK! Woo!!
              What's a skim key?
                I think he is refering to Skimsucka, another member here.... they aren't far away from each other? so they've tried their keys in his ignition... correct me if I'm wrong?
                Andrew Walker
                Current Daily Driver:
                89 Nissan D21 SE V6 5 speed 4x4
                Projects in the works:
                84 Mercedes Benz 300D(T)(Baby) currently awaiting transmission transplant/ full on restoration
                  Remove the door panel, peel back the plastic shield. Then remove the rod from the lock cylinder, then pry the retaining clip off the lock cylinder. Then it should slide out.
                  '90 LX
                    You might try a knife blade, GENTLY! A small pocket knife blade would open my first 88's drivers door, and the second 88's drivers door, hatch and gas lid. Second one had more miles.
                    Paul
                    Red Rocket 1988 L, 133,XXX miles, 4 sp. AC, hit guard rail in snow, RIP, saved everything but body
                    Black Rocket 1988 L 207,XXX miles, 4 sp. AC, engine, trans, wire harness, radiator from RR
                    Red Rocket 2 1988 L 138,XXX miles, 4 sp
                    White Rocket 1989 L 128,XXX miles, 4 sp. AC
                      If you are locked out, find a festy key or one that is the same size, and make a bump key.
                      1990 White L-Plus 5-speed rust-machine
                      Scrapped
                      1991 Blue L 5-speed
                      daily driver, intermittent project
                      1993 rustless wonder
                      A shell, awaiting suspension, brakes, and B6T
                        perfect! Thanks.
                          It's the ignition, thanks.
                            How does a bump key work by the way?
                              Ive taken the tumblers out of quite a few over the years that I bought without keys and the passenger door was changed. I wouldn't recommend it though Unless it's your only option. The nice part is any key that fits, works. The bad is everyone on here has a key for your car.
                              (paperboy 23) 88 Festy Blue, aspire Engine/trans/efi swap,
