What can I do please.
Lost my ignition key to my 88 and 89 festiva
Remove your passenger side door lock cylinder. It has a key code on it that any reputable locksmith can use to make a key.Last edited by doylerl; 04-08-2011, 05:58 PM.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
I think he is refering to Skimsucka, another member here.... they aren't far away from each other? so they've tried their keys in his ignition... correct me if I'm wrong?Andrew Walker
Current Daily Driver:
89 Nissan D21 SE V6 5 speed 4x4
Projects in the works:
84 Mercedes Benz 300D(T)(Baby) currently awaiting transmission transplant/ full on restoration
Originally posted by Tom View PostThat is really good news, thank you. I don't know how I'm going to get those locks out but I will get it done. Thanks again.'90 LX
You might try a knife blade, GENTLY! A small pocket knife blade would open my first 88's drivers door, and the second 88's drivers door, hatch and gas lid. Second one had more miles.
PaulRed Rocket 1988 L, 133,XXX miles, 4 sp. AC, hit guard rail in snow, RIP, saved everything but body
Black Rocket 1988 L 207,XXX miles, 4 sp. AC, engine, trans, wire harness, radiator from RR
Red Rocket 2 1988 L 138,XXX miles, 4 sp
White Rocket 1989 L 128,XXX miles, 4 sp. AC
Ive taken the tumblers out of quite a few over the years that I bought without keys and the passenger door was changed. I wouldn't recommend it though Unless it's your only option. The nice part is any key that fits, works. The bad is everyone on here has a key for your car.
