Yesterday I had the great idea of putting some Seafoam in the engine via a vacuum line. Everything seemed to go well until I got in it this morning and the alternator light was on while driving. I dripped a little Seafoam while pouring it in and thought maybe it got on the belt and making it slip. Bought some belt dressing and sprayed the belt with no luck. When I got home I checked with my volt meter and had over 15V while idling. I either got some Seafoam in the alternator while it was running and shorted it out or it was because I over revved it for a second. I used a pipe wrench on the gas pedal to keep it running and it bounced off the rev limiter for a second or two. I suppose I should just go get a rebuilt alternator or has someone experienced this and know of a cheaper fix inside the alternator.
Overcharging
Overcharging
Rick
1993 Ford Festiva
2000 Ford E350Tags: None
Originally posted by denguy View PostSounds like the voltage regulater in the alternater isn't working anymore. Should hold at about 14 volts when running. Keep running it the way it is and you will burn up your battery.Rick
1993 Ford Festiva
2000 Ford E350
FIXED!!!!!!! I was going to remove the alternator and when I went to remove the one connector, it came right off. It was barely connected. I snapped it in, started the car and the light was off. Checked with a voltmeter and it was at 14.18V. That was easy. :hello1:It must have been like that since I bought the car and it was just a coincidence that it happened when it did.:wav:Rick
1993 Ford Festiva
2000 Ford E350
One thing you can do as a temp fix if your voltage regulator isn't working: turn on accessories like lights, the heater (or A/C) and radio. That will suck up some of the voltage and hep prevent the battery from getting cooked.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by Eaglefreek View PostFIXED!!!!!!! I was going to remove the alternator and when I went to remove the one connector, it came right off. It was barely connected. I snapped it in, started the car and the light was off. Checked with a voltmeter and it was at 14.18V. That was easy. :hello1:It must have been like that since I bought the car and it was just a coincidence that it happened when it did.:wav:Trees aren't kind to me...
Originally posted by TominMO View PostOne thing you can do as a temp fix if your voltage regulator isn't working: turn on accessories like lights, the heater (or A/C) and radio. That will suck up some of the voltage and hep prevent the battery from getting cooked.-Zack
