Is the plate down there the choke..? This is the first car I've owned, and worked on. My untrained eyes need visual confirmation :tard:
If it is, it looks closed? I also couldn't verify if the choke was recieving 7 volts. I can't get the thing to run unless it's hot, and my issue is with it being cold haha. Plus, how are you supposed to check it with the air intake assembly on? It shouldn't run with that taken off, right? I was able to at least check the wire for continuity and tests were good.
Good luck
