What are some things that can be done to improve car. I read a post about EGR valve cleaned. Got any suggestions?
routine maintence
Spark Plugs (wires if needed)
Oil change/filter
Coolant flush
Filters (air,fuel)- Alot of people drill holes into the air intake housing just under where the filter sits. That will allow more air flow and improve performance, a little.
Check the brakes all around. Make sure none of them are dragging or that you don't have any weeping brake cylinders.
Check tires/pressure
Some people like to run a can of sea foam. It has worked great for me in the past.
Maybe put some fuel additive in your next tank.
Give it a wash and wax and call it a day!
That's some to get you started
My Musica! Click me!
Check tire pressure.
Change transmission fluid.
Grease wheel bearings.
Oil hinges and cables.
Check idle speed and timing.
Check valve lash if valves noisy.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
