My dad's festy is not starting,
New battery,
New fuel pump,
New coolant tempurature sensor,
New O2 sensor,
New distributor cap,
New rotor,
New spark plugs,
New rotor,
New Air Filter,
Used ECU,
Used idle bypass,
Fuel pump relay tested good,
Ignition module tested good,
Distributor tested good as per the sticky....
Starter tested good,
Alternator tested good.
Coil tested good.
We are getting spark...as per coil wire with spark plug to chassis test.
I even tried yelling at it and when that didn't work, i sweet talked it a bit but no change.
New battery,
New fuel pump,
New O2 sensor,
New rotor,
New spark plugs,
New rotor,
New Air Filter,
Used ECU,
Used idle bypass,
Coil tested good.
