Looked a little closer now that I'm home, all the grounds seem fine, the belt has some minor cracks in it but doesnt really seem too shiny.
Is my alternator going out?
replace the belt....cracking means it is getting brittle and hardening which will make it slip.Originally posted by devon527 View PostLooked a little closer now that I'm home, all the grounds seem fine, the belt has some minor cracks in it but doesnt really seem too shiny."FLTG4LIFE" @FINALLEVEL , "PBH"
Well my dad and I think the bearing is toast in the alternator, he went to go feel the tension on the new belt and burnt his hand on the alternator. there goes $110 that should go towards my streetbike...
88 Festy L (The White Thunder)
91 L came and gone, owned only 2 days
could always get one and have it tested at autozone...if it does not work take it back and get another or get a due bill if there is no refund. Check ahead if they guarantee it working.Originally posted by devon527 View PostThere are but I dont know if i trust those... lol"FLTG4LIFE" @FINALLEVEL , "PBH"
Thats a great idea, I think I might head to the junkyard right now, its 4 here and they close at 7 so I have timeOriginally posted by GenevaDirt View Postcould always get one and have it tested at autozone...if it does not work take it back and get another or get a due bill if there is no refund. Check ahead if they guarantee it working.
his plugs are different then the 90-93 Festy's...so they may not workOriginally posted by crazyrog17 View PostDon't forget about alternator upgrades like those from the 323s and MPVs. Direct bolt in/plug in as found across the site."FLTG4LIFE" @FINALLEVEL , "PBH"
Yes gonna have to do some rewiring on an early to use a late alternator like the 323. We had to do one for Batstiva to get him home from Madness4. You were there for that weren't you GenevaDirt?Originally posted by GenevaDirt View Posthis plugs are different then the 90-93 Festy's...so they may not work91 Festiva GL "Scrat"
82 Honda Goldwing GL1100i
85 BMW 535is "Brunhild"
A worldwide reman is about $140, and a Beck/Arnley will run about $160 for a carby and you may have to wait 2 or 3 days to get one. I keep a couple cores here, I can test one or two and see if I have a good one you may be able to use.91 Festiva GL "Scrat"
well....I thought I was....lol. But I do not recall the rewiring thing....wait...what is the number of madness coming up...lol.Originally posted by kartracer46 View PostYes gonna have to do some rewiring on an early to use a late alternator like the 323. We had to do one for Batstiva to get him home from Madness4. You were there for that weren't you GenevaDirt?"FLTG4LIFE" @FINALLEVEL , "PBH"
Just need the two alternator wiring diagrams to match the wires, and the plug of a 90-93 Festiva alternator and your set.Originally posted by devon527 View PostIs it hard to wire a 91 alternator into my 88? I cut the wires pretty far back so I have all of the wires, just dont want to tear into it if its too hard91 Festiva GL "Scrat"
