I'm unable to remove my rotors does anyone know how to do this ?
1988 Festiva L rotor removal
You need a press.
And a manual!
Welcome to the site!'93 Blue 5spd 230K(down for clutch and overall maintanence)
^^ Like John said. You need the Haynes manual to walk you thru the process--or convince you that you can't do it alone and take it to a shop.Originally posted by Pu241 View PostYou need a press.
And a manual!
Don't be afraid to search. Here is a thread about front bearing removal, but it also describes rotor removal. http://www.fordfestiva.com/forums/sh...=rotor+removal
But get the Haynes manual, you will need it.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Welcome, JIMITHING. I'll be the first to ask where you're from. Removing the rotors of course means pulling the whole hub assembly apart after you remove it from the car (so much for me lurking, eh Smedley?), so doing so would be the best time to have the knuckles cleaned, new bearings installed (DON'T LOSE THAT CENTER RING!), and checking your lower control arm bushings. I would recommend purchasing more pinch bolts, just in case yours strip out when you try to retorque them. You'll see what I mean in the Haynes manual.In love with a MadScientist!:thumbright:
The rotors can be removed with a hammer if you don't intend to use them any more. That's how I removed the rotors from the wheels I'm rebuilding with new parts. The bearings came off with a 3-prong puller on loan from the auto parts store. The rotors can probably be removed with a soft hammer even if you do intend to reuse them.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
That's why we doing the bearings at the same time.Originally posted by JIMITHING View PostThanks for the info guys I just ordered a manual online. That's a bit of a project just to replace a couple rotors.
It's also one of the reasons the Aspire swap is so popular.'93 Blue 5spd 230K(down for clutch and overall maintanence)
This is a great time to do a search on your own. This swap is well documented here. "aspire brake swap"Originally posted by JIMITHING View PostWhat does the Aspire swap consist of?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Excellent point, TominMO!Originally posted by TominMO View PostThis is a great time to do a search on your own. This swap is well documented here. "aspire brake swap"'93 Blue 5spd 230K(down for clutch and overall maintanence)
You can do the rotors without removing the wheels from the car. There are old postings in this forum describing how to do it. Essentially you use a 3-prong puller to pull the hub off the axle leaving the steering knuckle on the axle.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
The "aspire brake swap" seems like alot of work. I think I f I just replace the rotors this time they will probably last as long as the car does. Why can't I take a sledge hammer and hit rotor off since I'm going to replace it anyway? Will I be doing some other damage? I just don't see why I must take off the whole steering knuckle assembly.
the hub should be pressed off the inner bearing, hence the knuckle removal (plus it makes things SO much easier in the long run). if the bearings are in good shape and there's no play, press the hub off, unbolt the rotor, replace and then CAREFULY press back together with some fresh grease on the rollers.
DO NOT loose the spacer ring that sits between the inner and outer bearings.Trees aren't kind to me...
