I have a kind of growling noise going on. I can tell its definetely out of the passenger side of the motor. Maybe something in the timing belt area. It seems to be the worst when I am pulling from a stop in low gears and the gets quieter. It does still do it when idling but its not as loud as when its under a load. Anyone have any suggestions?
weird noise
While your idling are you rolling or stopped.
Because if rolling, the growling sound is likely a front bearing going.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Maybe a pulley, or the timing belt adjuster, or the water pump bearings starting to go. Do you have coolant coming out of the little hole on top of the WP?
The fact that it gets louder when you apply load for acceleration makes me think it has to be related to something that is belt-driven.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
OK, possibly the timing belt tensioner.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Don't replace the timing belt unless it needs it. If it doesn't need replacing, wait until the WP nees replacing to replace the belt. Less work.Originally posted by crusher773 View PostI'll check the water pump. Just the location its in makes me think its something to do with the timing belt too. I am going to replace the timing belt while I am in there doing that head gasket too.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
just for grins, also check for thrust play (in/out) at the crank pulley...Trees aren't kind to me...
if you're prepared to do a head gasket, everything else is a breeze.Trees aren't kind to me...
