H300
  • H300
    H300 relay. What does it control. That is what keeps clicking. I took it out and put it back in. Now check engine lights is blinking fast
    Sent from my PC36100 using Tapatalk
    First time owner
    89 L carb'd - white / still needs work
    Bought for mpg and only paid $250
    Bump. I need part#
    First time owner
      where is the relay located? sometimes the ecm will remember a fault code, disconnect the neg battery cable for a while (10-15) min and try hooking it back up to clear the code if that is the problem
        It's located by my feet.
        First time owner
