hi all i own a 1993 5 door 5 speed festiva and it constantly overheats ive taken out the thermostat replaced the waterpump radiator flushed it but then i took the top hose of the thermostat run the car but noticed there was no water flowing through the thermostat just steam and spits of water could there be a blockage in the head lost on what to do =/ any suggestions thanks.
overheating
clogged heater core maybe?89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
My site: 20tessa.sytes.net
Originally posted by 91_festy_Gl View Postclogged heater core maybe?Originally posted by DrMaxwellEdison View Postdid you check the heater core really good?
htchbck, I think he replaced the water pump.
It's hard to follow due to lack of any punctuation besides the single period at the end.Last edited by Pu241; 05-10-2011, 12:20 PM.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Originally posted by Pu241 View Posthtchbck, I think he replaced the water pump.
It's hard to follow due to lack of any punctuation besides the single period at the end.No festiva for me ATM...
Originally posted by Pu241 View PostPlease describe how a blocked heater core would cause an overheat condition in the engine?
It's hard to follow due to lack of any punctuation besides the single period at the end.Last edited by 91_festy_Gl; 05-10-2011, 02:54 PM.89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
I had to edit my post because it would have started a argument with a MOD. atleast you understand.89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
hey guys thanks for the replies. i only bought the car a few weeks ago. knowing that it was overheating there is water in the oil so that indicates not a cracked head maybe head gasket. i still have all power untill the pressure builds up . i have replaced the waterpump. Taken the thermostat out due to winter weather here in adelaide . the heater does not work but the vents do. but as i had said in the previous message i took the top hose off of the thermostat housing then started the car and noticed there was no water flowing out just steam even without the thermostat in ?
overheating
hey guys
i bought th car a few weeks ago for 180 there is only one problem it just over heated .
I have replaced the waterpump. Taken the thermostat out due to cold weather here in adelaide. i have replaced all hoses . checked the oil for water but theres no indication leading toward a cracked head maybe gasket? insured there is no air once radiator is filled. cooling fan does work . But still no water seems to be flowing through the thermostat housing. my heater for the car does not work but that shouldnt be a problem should it ? thanks guys
Originally posted by 91_festy_Gl View PostI had to edit my post because it would have started a argument with a MOD. atleast you understand.
Don't edit yourself on my behalf, Wont be the first time I've had an argument, guaranteed it will not be the last.
Bring the facts and lets see what the OP finds.
Just wanted to know how a clog heater core could cause and overheat in the engine. Neither of you have explained that. Many people have perfectly fine running cars with blocked heater cores, they just don't have any heat.'93 Blue 5spd 230K(down for clutch and overall maintanence)
