Originally posted by ELUSIVE
Aspire swaybar on Festiva woes
Originally posted by blkfordsedan View PostIn theory, yes. It should be used in conjunction with a rear bar200,000KM milestone!
aah im understanding now. I've got my aspire swap minus front bar. May have to grab that aswell. Just wanted to be sure and not compromise handling. Maybe both aspire bars with a bit of slight mod to the rear bar would be best60% of the time it works, every time!
I just installed the 5/8" threaded bar in my stock Festy rear beam. HUGE difference in cornering! No roll at all. I do have the Aspire front sway bar too.
Since I have 185/60x14 tires on rims with 38mm offset, I couldn't go with the 40.5" rear bar length. I had to cut it down to 40.0", and couldn't use the Nylock nuts, which are longer. So I used regular nuts with lots of loctite, and let it cure overnight. I only put the nuts on the outside of the beam, none on the inside, but it seems to work great.
Also, after a short drive I checked for rubbing, since the tires were still suspiciously close to the nuts. I saw very slight rubbing on one side, caused by the tire deforming when going around corners. So I installed a 3/16" spacer on each side; now there is plenty of clearance.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by TominMO View PostI just installed the 5/8" threaded bar in my stock Festy rear beam. HUGE difference in cornering! No roll at all. I do have the Aspire front sway bar too.
Also, after a short drive I checked for rubbing, since the tires were still suspiciously close to the nuts. I saw very slight rubbing on one side, caused by the tire deforming when going around corners. So I installed a 3/16" spacer on each side; now there is plenty of clearance.1988 Chevy Sprint Turbo 997cc
Where did you get the poly bushings and what did it cost you?1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
Originally posted by 71Montego View PostPlease take into account if you go from bad bushings in the front to anything new, either the stock sway bar with urethane or the larger Aspire you will notice a big difference.Brian
Originally posted by Brayy View PostGuessing you got yours back on the road ?
Originally posted by Aaronbrook37 View PostInteresting... must be the spacers. Either way, glad to hear you got it hooked up, Tom! It's easily one of my favourite cheap mods for these cars. Paired with the Aspire beam, it's just killer. Anybody looking to do a handling upgrade without one of these first should reconsider their budgeting!
Originally posted by 91mcnasty View PostWhere did you get the poly bushings and what did it cost you?
Originally posted by ELUSIVE View Post^^x2. Are they a pedders item? Also, love your super cheap auto stands. Went to get a pair yesterday on sale but EVERY store in perth had sold out of the ones I wanted200,000KM milestone!
Originally posted by blkfordsedan View PostVery true. I think with the stock Festy front sway bar, just adding urethane bushings to make it more effective would be enough to counter act any oversteer created by adding an Aspire rear beam (or threaded rod). These cars have soo much body roll in stock form that anything helps.200,000KM milestone!
