I noticed some "play" in the steering, (88 festy btw). When I jack the car up, and move the tire from side to side, there is some play coming from the inner tie rods or inside the rack. This play is noticeable on both sides. Clues?
Play in steering, help!
Yeah, take a good look at the tie rod ends. I'll bet the boots on one or both are shot. Replace 'em. Use Moog tie rod ends; they last longer. If, before you remove the old ones, you count the threads that are showing, you can put the new ones on to that same thread location, and not have to re-align the steering.Originally posted by htchbck View PostSounds like you're already on the right track diagnosing it. It could also be from the outer tie rods as well.
Also take a look at your lower control arms, under the knuckle where the ball joint is. Again look at the boot condition. Those can actually pop out from wear if the boots have been torn for a while, which is a very bad thing safety-wise. Moogs are best here too.Last edited by TominMO; 05-16-2011, 06:46 AM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Sounds like the inner tie rods might need replacing too. And replace the boots if they are torn.Originally posted by fstamand View PostForgot to mention, popped the outers out and there is still play from inner/rack... I guess the next step is to pull the boots out and inspect?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
So you'll be replacing everything I guess. The main reason to go with Moog is that the rubber on their boots seems to last longer. But you can go cheap if you have to; just keep an eye on the tie rod end boots (and lower control arm boots too). Evey six months or so, squirt 'em with Armor-All to lengthen their life.Originally posted by fstamand View PostYeah all the boots are cracked, time to make moog stocks go up
$25 weekly? Does he have a special 6-gallon gas tank?Originally posted by gotrootdude View PostIt'll quickly become your 30min-hour weekly project as you add driving lights, seat-steering wheel covers, DIY hatch cover, LED brake light, do your own oil-changes/tune-ups, etc.. Get used to the $25 weekly fill-up.
Did did you determine the complete problem.Originally posted by fstamand View PostI noticed some "play" in the steering, (88 festy btw). When I jack the car up, and move the tire from side to side, there is some play coming from the inner tie rods or inside the rack. This play is noticeable on both sides. Clues?
Thought mine was the inner tie rod but turned out to be the rack bushing.
Had to get it rebuilt.
