Check engine light
  • Check engine light
    Check engine light came on. Steady. Then I slow down and it went off. What's the cars problem now?
    Sent from my PC36100 using Tapatalk
    First time owner
    89 L carb'd - white / still needs work
    Bought for mpg and only paid $250
    Typically, the check engine light is related to the emissions of the car. You could have a bad converter, a bad O2 sensor, or a fuel mixture problem that causes the emissions to go out of range. I don't think these cars are OBD2 compatable (only been an owner a week and a half myself) so I don't know if you can go to AutoZone and get the codes read, but it sounds like it only does it under a load. Hopefully someone more versed will chime in.
      OBD2 started in 1996, halfway thru the Aspire generation.
      If you get the O2 sensor, make sure it's the Denso unit. There are two, but they are identical except that one needs to be spliced in with the existing wiring; that one is much cheaper, about $20.
        Car is OBD-I only, there is a thread on reading the check engine light codes, but the fact that it comes on then goes off on it's own is perplexing
          I'd check what part of the car the code is referring to and start by looking for a loose or corroded connection.
            Where is the O2 sensor located? Pics?
            First time owner
              This happens all the time.
              Sometimes it takes specific conditions to trip the light, if the conditions are correct it will go out. Intermittent sensor failure, failure only when warm or cold etc...
                It's sticking out of the exhaust manifold. Looks vaguely like a spark plug with a wire on the end.
                  In the front of motor facing front passager side ?
                  First time owner
                    You are correct.
