Valve cover help needed!!
  • Valve cover help needed!!
    Started to pull the valve cover today, i'm stuck, do i have to pull the intake manifold of to remove it? Quick responses appreciated.
    :cry_smile: RIP. 91 Ford festiva BP swap
    1990 Mazda Miata BP swap, 99 trans, 3.9 Torsen rear end, Mazdaspeed6 k04 turbo on 15 psi.
    Bump or manually rotate the crank.
    One or more of the rocker arms is in the wrong position.
    Or remove the throttle intake.
      What about removing the throttle body instead? If IIRC it uses some studs. So, you can use pliers or 2 nuts like #1 on this link:
      1993 GL
        Which way am I best off coming off sliding it to the side or tilting and coming up? Thank you.
          Don't understand your question...
          As mentioned, remove the throttle body and pull straight up.
          Remember to get a new throttle body gasket and DO NOT OVER TIGHTEN THE VC BOLTS. They need to be tightened down in INCH POUNDS. Just tighten them until the rubber bolt bushings are squeezed out of shape a bit.
          -Zack
            There is a bolt that holds the valve cover that goes through the timing belt cover.
              Valve cover was real easy to take off mine.
              sent from my FESTIVA on me EVO phone
              First time owner
              89 L carb'd - white / still needs work
              Bought for mpg and only paid $250
                It's harder on the EFI models because the throttle body extends over the valve cover.
                  +1. I've never had to remove the throttle body. It does take some wiggling, but it comes off.
                  Try putting the car in 5th gear, parking brake off, on a flat surface. Pull on the cover while pushing the car with your body. Whichever intake valve was too high will go down, and off it comes.
                  Edit: I changed my mind on my advice. Instead drop in a gen 2 (1990 -1993) B6; nothing obstructing the valve cover.
                    I got it off, any advice for cleaning it?
                      Brake cleaner (spray can).
                      When you install the new gasket, squirt it all over with Copper-Coat first.
                      Hurry; you only have about 70 minutes until the rapture....
                        Thanks for the laugh, and I'm talking about the top, visable surface
                          Still with the brake cleaner, unless it's painted; then go with something that won't eat the paint, like Simple Green or maybe foamy Engine Brite.
                            I'm having no luck
                              Castrol Superclean and a stiff brush. You may have to go over it a couple of times but I haven't seen much this stuff won't clean
                              WWZD
                              Zulu Ministries
