Started to pull the valve cover today, i'm stuck, do i have to pull the intake manifold of to remove it? Quick responses appreciated.
Valve cover help needed!!
Bump or manually rotate the crank.
One or more of the rocker arms is in the wrong position.
Or remove the throttle intake.'93 Blue 5spd 230K(down for clutch and overall maintanence)
What about removing the throttle body instead? If IIRC it uses some studs. So, you can use pliers or 2 nuts like #1 on this link:
1993 GL
Don't understand your question...
As mentioned, remove the throttle body and pull straight up.
Remember to get a new throttle body gasket and DO NOT OVER TIGHTEN THE VC BOLTS. They need to be tightened down in INCH POUNDS. Just tighten them until the rubber bolt bushings are squeezed out of shape a bit.-Zack
+1. I've never had to remove the throttle body. It does take some wiggling, but it comes off.Originally posted by Pu241 View PostBump or manually rotate the crank.
Try putting the car in 5th gear, parking brake off, on a flat surface. Pull on the cover while pushing the car with your body. Whichever intake valve was too high will go down, and off it comes.
Edit: I changed my mind on my advice. Instead drop in a gen 2 (1990 -1993) B6; nothing obstructing the valve cover.Last edited by TominMO; 05-21-2011, 02:29 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Brake cleaner (spray can).Originally posted by mckabe View PostI got it off, any advice for cleaning it?
When you install the new gasket, squirt it all over with Copper-Coat first.
Hurry; you only have about 70 minutes until the rapture....Last edited by TominMO; 05-21-2011, 02:43 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Still with the brake cleaner, unless it's painted; then go with something that won't eat the paint, like Simple Green or maybe foamy Engine Brite.Originally posted by mckabe View PostThanks for the laugh, and I'm talking about the top, visable surface90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
