The guy at the parts store said to clean the gunk off the new rotors before use. Research on the Internet says hot soapy water is okay if you don't have brake cleaner. Anyone confirm this?
Research on the Internet also suggests breaking in (bedding) new rotors and tells how. Basically applying brakes in a controlled way to heat up the components and then cool them off. All done while car is in motion. Anyone do this? Components last longer or brakes work better? (Am putting on new rotors, calipers, pads.)
Thanks.
Thanks.
