Mine would whine all the time. The input shaft rests in the pilot bearing, correct? So, the flywheel never stops turning, right?
 The throw out bearing was buggered, thus the hard pedal. I don't think I was clear on that.
I would definitely test the accessory side first, there is a lot less involved. If all else fails, THEN I would worry about inside the bell housing.
 The throw out bearing was buggered, thus the hard pedal. I don't think I was clear on that.I would definitely test the accessory side first, there is a lot less involved. If all else fails, THEN I would worry about inside the bell housing.
