i am a new festiva owner and other then needing a few things fixed from what i can tell its in top shape...i am not car wizz in fact i was a WoW nerd till i got it for my 21st for this reason i have no clue whats what, i have this metal pipe coming out of radiator and it pretty much goes around my hole engine and then turns into a rubber pipe nare the backof the engine, the problem is its spitting out more water then i can poke a stick at, 4 main holes and 2 dripping ones could i fix this at all? if not whats it called so i can replace it also have oil slowly leaking from the metal square thing with spark plugs in it again whats it called and what could be wrong with it? i get my P's in 6-7 months so i am hoping to have it ready for the pits
thanks for any help and advice
P.s 1993 for festiva 5 door hatch manuel
na this pipe is leaking bad , if it was a boat it would sink
, i can put the hose on full and blast water out of the metal pipe the holes are all close they are in a cervy part of the pipe right past that metal plate on the frount of the engine ,
And you came to the correct place for help & to learn about your Festy! There are other Festiva & Aspire owners in Aussie Land. Welcome to the site!!:profileleft:
