Picture of idle adjustment screw- fuel injected models
  • Picture of idle adjustment screw- fuel injected models
    Hi. I have a '90 fuel injected LX that has a low (as in 100rpm) idle speed. This causes it to die unless you rev it constantly, which is impossible in a manual car without a 3rd foot. I have an idea of where the screw is, but want a picture of it to be 100% positive I'm turning the right one. The festy is sitting at the previous owner's house until I fix the bad idle issue, so any help is greatly appreciated. Thanks.
    1990 White L-Plus 5-speed rust-machine
    Scrapped
    1991 Blue L 5-speed
    daily driver, intermittent project
    1993 rustless wonder
    A shell, awaiting suspension, brakes, and B6T
    here's a video, look at the throttle body hole then look to the 1 o'clock position, you'll see a dark spot. to it's 4 o'clock position is the idle speed screw tube, the screw is in there!
      Scrapped
      1991 Blue L 5-speed
        Yup!!!
          Thanks. I knew it was somewhere up there, lol.
          Scrapped
          1991 Blue L 5-speed
