Hi. I have a '90 fuel injected LX that has a low (as in 100rpm) idle speed. This causes it to die unless you rev it constantly, which is impossible in a manual car without a 3rd foot. I have an idea of where the screw is, but want a picture of it to be 100% positive I'm turning the right one. The festy is sitting at the previous owner's house until I fix the bad idle issue, so any help is greatly appreciated. Thanks.
Picture of idle adjustment screw- fuel injected models
here's a video, look at the throttle body hole then look to the 1 o'clock position, you'll see a dark spot. to it's 4 o'clock position is the idle speed screw tube, the screw is in there!Trees aren't kind to me...
Yup!!!Trees aren't kind to me...
