Hello, I am new here. I'd like to say thanks for having this available. I was wondering if anyone had any diagrams or disassemble instructions for the manual trans. I have a 92 and the trans had a busted shift gate. so My friend fixed it when he owned the car and it never moved again. The shifter wouldn't move at all into any gear what so ever. I know its simple so I pulled the trans again and I cant get the one cv axle out of the damn transmission. Ive had one guy standing on the trans while 2 guys had pry bars that they were standing on with their full body weight while I was smacking it with a hammer. I'm ready to chain it to a tree and pull it out with the tractor! Any Ideas? Thanks!
Manual Transmission Diagram and Help
1921 Model T
1940 Ford
1960 F600 Fire Truck
1963 Ford Falcon drag car
1964 Ford Falcon Futura
1964 1/2 Ford Mustang
1966 Ford F100
1973 Kenworth K100 Cabover 903CID Cummins
1976 F650 Dump Truck
1978 F150
1980 F350 Pulling Truck
1988 Ford Mustang GT
1990 Ford Mustang LX
1992 Ford Festiva
1992 Dodge D350 Cummins
2000 Ford F350 Super Duty 7.3 Powerstroke
You can't build a reputation on what you're going to do.-Henry Ford
Tags: None
you need to shock the retention ring into compression and it will slip out. place a prybar between the case and axle and smack the shaft of the prybar perpendicularly with a heavy hammer.Trees aren't kind to me...
An air chisel works wonders when combined with a pry bar. Usually only take one quick blip of the air hammer and it pops right out. It's never failed me yet.Last edited by gauge_half_inch; 06-04-2011, 03:42 PM.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
