1st thing that I think MAY be wrong. When I was removing the air box, I couldn't figure out how to unplug it. I took the two screws out and started to pull, that doesn't look right, so I put it back in. Finally figured out the spring clip.
Now, with the filter box totally buttoned up with the filter in it, if I spary carb cleaner into the opening inside the fender, it purrs like a kitten.
I pulled the fuel line of the intake, cranked and fuel came out, dunno the pressure but it's really varnished (car has sat since '08 as near as I can tell).
I've checked for loose connectors, disconnected vacuum lines, can't find anything wrong.
The reason I replaced the timing belt was because I thought it had slipped a tooth and I didn't know it's age. Water pump, because it was there.
I know it's timed right, the marks all line up and like I said, it purrs.
