sounds like its time to take it to a press. I helped a co-worker with a super super stuck universal joint on a drive shaft after work the other day, we put it in a hydrolic press and it took over 1000 psi to knock the thing out.
~Nate
Current cars:
Skeeter, I'm going to blame you for giving me the idea.
Instron manufactures tensile, compression, fatigue, impact, rheology, and structural testing machines, testing a variety of materials and range of applications.
So I wonder if I could use it as a programable press?
I can program it to stop if the load on the crosshead approachs the load cell limit of 5,000 lbs.
You really need to be carefully wailing away on the axle, you could actually bend the knuckle. It's definitely time to take the axle out of the trans and pull the knuckle and press it.
Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
how about trying the acetone and atf 50 50 mix. it is supposedly even more effective than pb blaster and should be cheap to whip up.
