No input on thread size, but I don't recommend using brass fittings...
1. Galvanic corrosion between dissimilar metals.
2. Brass will work harden with heating/cooling cycles, and can start leaking/break off.
Aluminum fittings, if you can find them, thermal plastic, or steel/iron.
