I installed an AC system off an ATX car on my MTX car. The question I have is the ATX cars had a seperate condensor fan and a third relay for the WAC if I recall correctly. The only plug that was missing on the install was the connection for the 20amp single plug with the inline fuse. I believe this is the one that supplys the power to the third relay and operates the condensor fan located in front of the condensor coil.
So will the AC system work without it being connected to anything?
If not where can I get a good power supply for it?
I plan to vacuum the system tomorrow and put the refrigerant in so I guess I will see if nobody knows the answer.
