tools I used to remove front wheel
  • tools I used to remove front wheel
    Ford Festiva front wheel tools
    Tools I used to take the front wheels of my 1989 Ford Festiva and
    put them back on.
    Jack and 2 small stands
    Socket wrenches
    17mm - tie rod end (torque to 26-30 ft-lb)
    - strut bolts (torque to 69-86 ft-lb)
    14mm - lower control arm pinch bolt (torque to 32-40 ft-lb)
    - lug bolts to remove tire (or lug wrench)
    12mm - brake calliper bolts (torque to 26-30 ft-lb)
    1 3/16" - axle nut (torque to 117-174 ft-lb) (see note 1)
    Socket drivers
    1/2" T-bar - good for breaking free old nuts and bolts
    1/2" swivel ratchet - (optional) saves time
    torque - for tightening nuts and bolts to spec (see note 2)
    6" extension - for torquing pinch bolt
    3' handle extension pipe - for extra leverage (see note 3)
    Open end wrenches
    17mm - to hold strut bolt while tightening
    14mm - to hold pinch bolt while tightening
    Crowbar - to wedge between lug bolts and keep wheel from turning
    Pliers - to compress brake pad to remove calliper
    - for cotter pin in tie rod end
    Stiff wire - to hang brake calliper from coil spring
    Drill and bit - to get rusted cotter pin out of tie rod end
    2-prong puller - to separate tie rod end from steering knuckle
    punch - to tap out pinch bolt and strut bolts first time
    - to stake axle nut so it won't turn
    dowel - to loosen axle so it can be pushed out of hub
    cold chisel or large screw driver - to wedge open pinch bolt slot
    hammer - to drive punch, dowel, and chisel
    optional trouble light, carpet to sit on, container for parts
    note 1 - for axle nut I used a 1-3/16" oil sending unit socket
    because it fits and is cheaper than the axle nut sockets at the
    parts store. Sorry, I don't know size of axle nut.
    note 2 - I have an old fashioned 0-150 manual torque wrench, not
    digital, which is large and cumbersome. It needs and extension to
    torque the pinch bolt. It's too long to do the calliper bolts.
    note 3 - My extension handle is cut from a discarded bicycle
    frame, the top bar (cross bar) and head tube (where the fork
    goes) which gives two angles
    I took things off in the following order
    - tire
    - axle nut
    - brake calliper
    - tie rod end
    - strut bolts
    - pinch bolt
    - axle and lower control arm together (wiggle to free)
    - END -
    .... I don't see a Bearing Splitter Separator on your list for removing the inner bearing off the hub. Of course, you'll need a small press to coincide with it. see pic
    .... Suggestion: If you smack the side of the KNUCKLE with a ball-pine hammer AFTER you take the tie rod nut off, normally the tie rod end just pops rate out of the knuckle. Some can be stubborn, requiring a brass drift OR a tie rod removal tool.
    .... Sharing some thoughts to make your job a little easier and less complicated.:thumbup:
    put them back on.
    Socket wrenches
    Socket drivers
    Open end wrenches
    - tire
    - axle nut
    - brake calliper
    - tie rod end
    - strut bolts
    - pinch bolt
    - END -
    A hunch is creativity trying to tell you something.
      Those tools are just for taking the wheel off the car and putting it back on.
      To pull the steering knuckle and outer bearing off the hub I use a 6" 3-prong gear puller which I borrow from the atuo parts store, and turn a big socket upside down on the end of the hub.
      To press the bearings onto the hub I use a spare axle and some rings cut from 1-3/4" plastic pipe.
