Just got home from work and put my first plug wires on. Because the guy I bought it from 'pretty much' fixed the gas line leak (which I found out was NOT the fuel line, but above the tank under the access panel), I put a little gas in the tank to see if the car would start. It turns over, has a slight backfire, but still no luck. Checked and no leaking underneath (to what I can tell). The part that IS leaking is the tank under the access panel, and the guy partially JB welded it, as you can see in the picture here:
I won't be trying to start it again until the gas leak is fixed. Do you think it can be repaired with a second (or third) round of JB weld? If not, what would be the best course of action?
Thanks!
~Spike
P.S.: Thought I'd add a picture of the engine, too.
Thanks!
~Spike
