...In the last two months. I don't know what's wrong. The diaphragm isn't holding up at all. The car doesn't want to idle at first, and after a few revs, will run. You have to DROP the pedal to accelerate beyond 2K, and then after that the car takes off like a rocket. Well, a 50HP rocket. I hope it's not just that the AutoZone fuel pumps I'm getting are crap.
Blown 2 Carby Fuel Pumps
Tags: None
Have you checked fuel pressure and output volume??Hotrod Forums Directory * D&D Discbrakes 61-67 Econoline Conversions
No, I haven't. I didn't have the means. I've been informed that the fuel pumps I was using were a bad brand and were prone to failure. I'll be receiving an OEM pump in the mail shortly.Last edited by DriverOne; 07-20-2011, 09:40 PM.In love with a MadScientist!:thumbright:
There is a (approximately 3/16") plastic spacer plate that goes between the head and the fuel pump. Do you have that installed? If that is missing, it's possible that the cam lobe is pushing the fuel pump lever too far because the pump is too "deep" into the head.You gonna race that thing?
Originally posted by Festy46 View PostThere is a (approximately 3/16") plastic spacer plate that goes between the head and the fuel pump. Do you have that installed?
Originally posted by Fordverde View Postanother thing, check that the return line isnt blocked!!In love with a MadScientist!:thumbright:
Originally posted by DriverOne View PostI thought the carby models didn't have a return line.You gonna race that thing?
