ok so i just picked up this car 1994 ford aspire base 5spd 3dr.
So i started looking at it and seen the fan wasnt pluged in and the po ran jumper wires from a switch to it i took that out and pluged it back in were its suppose to go. started car let it heat up and it isnt coming on? i checked the fuse near the battery and its good. Idk were i should check next?
Also i found a oil leak on the timing side of block idk yet if its maybe the oil pan gasket or the crank seal? the car has 155k miles on it.How hard is it to replace the crank seal and timing belt? Also lol i noticed on start up and hard revs it puffes a little smoke idk if theres any think to look for other then wore rings? And does anyone know whats good psi per cylinder for these motors? im going to do a compression test on it monday.Any help would b good Thanks
