Dude. I could take the sensor out and mail it to you if you need it. PM me your address if you are interested.
1994 Ford Aspire Need help!!
I see what you mean. Looked at the book. Think I did have to buy the switch when I installed the Aspire motor. I also used the original thermostat housing so that would explain why mine seemed different. Sorry. Don't want to send anyone in the wrong direction. My sensor sure won't do you any good.
Ok, one more little bit of information for you. The thing that sends the info to the gauge (and that Zoe is hopelessly fixated on) is actually referred to as the engine coolant temp "sender". The thing that sends info to the computer is referred to as the engine coolant temperature "sensor". Right, who's the engineer that decided we needed the semantics in addition to a non functioning coolant fan.
If you've got a haynes manual, you can see the "sender" wiring on the page called "1994 and later engine warning system" in section 12 page 30.
The sensor wiring system is located on the page called "1994 and 1995 engine control system" section 12 page 23.
Section 12 page 26 actually shows how the brown wire coming from the pcm energizes that relay, like I showed you how to do.
You can go to the rockauto online parts store to get a comparison look at the two different units (sender/sensor), That may help you to spot it, and as it turns out, replace it.Last edited by iceracerdude; 07-26-2011, 10:18 PM.
ok well im waiting for the title befor i go spending anything on this car (so abt 3weeks)
anyways i got around $200 to spend on it i would like to get
New: Brake pads/shoes/kit/rotors/drums ect
Oil change
lower ball joints/bushings
Spark plugs/cap&rotor/wires/air filter and fuel filter
radiator flush(have to pull out anyways long story)
o2 sensor
im hopeing to get the best mpg as i can and reliablity as ill be going like 400-500 round trips.
Any other sugestions?
and is there any way to get a little more pep out of the 1.3 lol ?
Ok, you'll have to explain what this ^ means, I'm slow that way.Originally posted by gearheadmike View Post...
and there nothing no cold air or anything exhaust sys?
Why don't you pick up a new sensor since all the testing is pointing at it
as the culprit?
i mean is there a good way of doing a cold air for this car?or exhaust mods for performance gains lol? And when i pulled the plug off sensor and turned key on it came on while the fan is running (key switch to start mode) when pluged in it quit so im gunna get one outa junk yard car for now,,as new is like $30 lol
