Hey everyone!!
1988 L+, 4-speed manual, 1.3l, carb, 171,000 miles
Having trouble starting it these days. Takes about 4 times, cranking the starter about 4-5 seconds each time, to start it. It should start on the first try, maybe the 2nd try if it's cold. Once started, runs great.
My alternator belt is slipping (I'm replacing it on Saturday), could it be that the battery is not being fully charged, therefore causing my problem?
would like to take care of this B4 I drive across country!!
Also, how hard is it to change: oil pan and valve cover gaskets, and the fuel pump? Any secrets I should know before I tear everything apart?
Thanks!!
mark
Thanks!!
mark
