I have a car that has a busted fusible link block. Has anyone replaced it? I pulled the spade connectors out and only the ground side and one connector are in good enough shape to reuse. The parts store fuse block only goes up to 20 amps and I didn't find any spade connectors big enough to use as replacements. Any ideas?
Fusible link block repair
I use automatic reset circuit breakers. If you get a short, they trip, but then reset themselves. You never have to replace fuses if you use these. Below is a picture of one.You gonna race that thing?
Or, you could go to an aftermarket stereo store and get some amp fuses and blocks.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
Thanks for the idea. I think I'm going to look in to doing this or something like it. Do you have a pic of this set up in your car?Originally posted by Festy46 View PostI use automatic reset circuit breakers. If you get a short, they trip, but then reset themselves. You never have to replace fuses if you use these. Below is a picture of one.
I only use one for racing because the only electric load I have is ignition coil, fuel pump, gauge lights, and in-car camera. I have it mounted to the firewall and marked as letter "C" in the picture below.You gonna race that thing?
Be careful with these tho... if you have a dead short you can still catch some wires on fire.Originally posted by Festy46 View PostI use automatic reset circuit breakers. If you get a short, they trip, but then reset themselves. You never have to replace fuses if you use these. Below is a picture of one.
