Need to do the either/or camber adustment due to tire wear issue on recently purchased 89. Unbolted 2 nuts and lowered strut but mount won't spin. How far does mount have to be below hole to spin 180 degrees? Thanx
camber adjustment 89
just have to clear the studs on the strut mount. as for tire wear, have your toe checked first, most people mistake toe wear for camber wear. 90% of the time it's a toe issue causing the one side of a tire to wear prematurely.Trees aren't kind to me...
should... if it's binding, that gives you a reason to upgrade to the rio strut mounts.Trees aren't kind to me...
