During my last timing belt replacement at 274K also replaced front crank seal that was leaking. Used punch to make hole for self-tapping screw. Seal came out okay but noticed that screw had "walked" toward crank leaving corkscrew-shaped scratch in journal. Sanded it with 220 grit sandpaper and reassembled. Was okay for a week or so then started leaking profusely. Have engine out. Any way to patch it up to milk the last few 20-50K miles out of it?
scratches in front seal journal
You should have filled in the scratch with a little JB weld. Then gently polished it smooth with 600 emery cloth. 220 is way to much grit. Without seeing it I would have to say you may be in need of a crank.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Im not sure if they make them for this engine or not but they are called speedy sleeves and i have installed several of them ... very easy quick fix for this issue ...Its just a very thin shim that gets tapped over the crank end and the seal is made to fit the sleeve .. they come in kits sleeve and sealNew build on the way .
Originally posted by shadetree View PostIm not sure if they make them for this engine or not but they are called speedy sleeves and i have installed several of them ... very easy quick fix for this issue ...Its just a very thin shim that gets tapped over the crank end and the seal is made to fit the sleeve .. they come in kits sleeve and sealJim DeAngelis
kittens give Morbo gas!!
I ended up filing the high spot a little then polished it with 1500 grit paper. Today I got a piece of 3000 grit paper and the journal now looks like chrome. If it still leaks I'll try a snout sleave. Won't know for a while cause it's a back-burner project since I have my '89 to drive.
