Can any one tell me where the computer is located on a 1992 ford festiva
computer
In the dash. If you stick your head where the pedals are and look up you can see it. Has a bright green plug going into it. Not sure if you have to take the dash out to remove it, as I've never done that.
No, you don't have to remove the dash, but it is kind of a PITA to remove.
1989 L - 247K miles Slick
Lots of nice, sharp edges up in there too. Be careful.Festiva: Because even my dog can build a Honda.
I just got mine out lol...only took one nosebleed and a fingernail nearly sheared off. It actually wasn't as hard as I had thought. It's two 10mm bolts on the bottom, (easier to use a wrench than a ratchet because of space.) and then just pry it out with a screwdriver. Took about a 1/2 hour. (Of actual work, not counting the time bandaging up the injuries. :p)
