Originally posted by FestYboy
cv nut too tight?
FestYboy,where did you get that spec? Both my (Ford) Festy & Aspire books call out 116-174 lb-ft. Has it been ammended and I'm not aware of it? Thanks,Thomas.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
^really? i seem to recall that spec from my 89 manual, i'll have to look that up again.
all i know for sure that anything over 150 is unnessisary/overkill, especially for our cars.Trees aren't kind to me...
we just over torqued it. it runs smooth now. i(being chris the boyfriend and person doing the work) used a jack and a 78 ltd to press it together. have had no problems. now just to do the right brakes and take a look at the back drum brake. and she'll be in great running condition.
:wav:
Clink... Clank... BOOM!
Yes,the book calls out for 145 ft-lb when setting & checking the bearing preload. So if you do the math 145 ft-lb is the middle of the 116-174 ft-lb torque range. I'm not sure why they have that range? Why dont they just torque the nut 145 ft-lbs like called out for bearing preload setup? Kinda strange huh? But I'm sure there is a method to their madness. I've just been torqueing the nut to the low range like yourself.....Originally posted by FestYboy View Post^really? i seem to recall that spec from my 89 manual, i'll have to look that up again.
all i know for sure that anything over 150 is unnessisary/overkill, especially for our cars.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
you do not change the spacer when you do a bearing swap...the spacer is for the hub.....the bearings are machined to a much closer tolerance so they are basically the same...one to another. Save the spacer and reuse it when doing the job and if you do it right everything will be fine.Originally posted by georgeb View PostNot to discourage anyone from tackling a hub rebuild, but it seems that the old spacer being the right thickness for new bearings is somewhat of a crapshoot. There are 21 different sizes of spacers (where would you get one?) and the right one is determined by the flaky and tedious method of using a sensitive torque wrench to determine pre-load after everything is pressed together. It also requires several pullers, adapters and a "pre-load selection" tool. It makes more sense to get a used one and save your old ones for a rainy day."FLTG4LIFE" @FINALLEVEL , "PBH"
Truth be told the spacer is for the knuckle, not the hub. The hub is not used in preload spacer selection, just the knuckle.
Truth be told.....you know what the hell I am talking about....:pOriginally posted by WmWatt View PostTruth be told the spacer is for the knuckle, not the hub. The hub is not used in preload spacer selection, just the knuckle.
I do not see anyone arguing ... I see a discussion.Originally posted by georgeb View PostBut we're not done arguing.
I mentioned that....in post #6Originally posted by GenevaDirt View Postyou do not change the spacer when you do a bearing swap...the spacer is for the hub.....the bearings are machined to a much closer tolerance so they are basically the same...one to another. Save the spacer and reuse it when doing the job and if you do it right everything will be fine.
Dan
I know that....but as you see in the post I quoted...I believe #11, they either didn't read it....didn't care....or don't believe it. So I stated it again. There is another thread going also that has some of the same talk going on.Originally posted by drddan View PostI mentioned that....in post #6
