There a few parts of the BP swap guide that have me confused, hopefully some one can help me out.
How do I add wires to the ECU plug? (VICS and CID)
Also, the guide states that the 2 temp sensors on the water neck are different. The water neck is where the upper radiator hose goes to, correct? The green coolant temp sensor plug on my Festiva harness connects to the sensor on the BP without modification. Is the guide correct? How do I wire these two plugs?
