so i have had my festiva for a week or so and have fixed alot of lil things and now im stuck.
after i take a 15+ min drive and shut it off it will not start without the petal to the floor and cranking for a few seconds to a minutes and when it starts the petal still to the floor(or it stalls) it takes 30+ seconds to get above 2-3 hundred rps and then its unstoppable till it shuts off. i checked the fuel pump it has 32 psi of pressure and i sprayed starting fluid on the vacuum lines and no idle difference. it bogs pretty hard and is sluggish at times but i cannot figure it out.
any ideas?
thanks, Jesse
any ideas?
thanks, Jesse
